Hyperlinks in HTML signatures on IMac
Hello, How do I add a Hyperlink to a HTML signature in Thunderbird on IMac? I've added the code buy it gets added as text not a link. Thanks!
Post a screenshot of your HTML sig to get better feedback. It may not post directly within text, but you could do a large photo of it and post that.
Hello, the following is an example of the code I used: <a
href="http://www.talktodieter.com/" target="_blank" style="color: rgb(17, 85, 204); font-size: small; font-style: normal; font-variant-ligatures: normal; font-variant-caps: normal; font-weight: 400; letter-spacing: normal; text-align: start; text-indent: 0px; text-transform: none; word-spacing: 0px; -webkit-text-stroke-width: 0px; white-space: normal; background-color: rgb(255, 255, 255);">www.TalkToDieter.com
Well, the HTML is poor and will never work. I made no attempt to make it pretty, just to function. I added XXXXX just to have some text. The output is not pretty, and I encourage you to seek a pro to do this. This forum is not intended for giving tutorials in HTML. The attached screenshot works, but I suggest more work.
